hello, ive had a voyager rme for a little now an have just about got my head round most of the basic functions on the front panel, however ive just been given a murf 105, which i can get some great sounding vocal effects out of by running a mic thru, but id like to be able to sync it to my voyager’s LFO and Key Press and then be able to sync the voyagers LFO to abletons midi clock. How do I go about this? Do i need any special cables, any help would be just mmmmagical
Cheers
CT
You need a VX351 for the LFO outs, to sync the Murf to the Voyager’s LFO and keyboard gate.
Syncing the Voyager’s LFO to anything else is a challenge because it’s an all analog LFO. All you can do is sync the start, and have to manually set the LFO to a fraction of the tempo. Good luck with that, as I don’t use ableton so I can’t help you but Im sure you can get some more info here.
sweet, thanks for that mate, i just ordered the 352, my next question is, do cv’s use a regular 1/4" Jack cable, balanced or unbalanced best if so?
Cheers
CT
