Everybody with monophonic synths intermittently gets mild audible popping sounds on fast amp envelope attack when the filter cutoff is low enough. Now imagine those “attack pops” to be overtly loud, and increasing amp envelope attack up to 40% of the maximum, and still hearing them. Couple that with the weird behavior in that when amp envelope Release is increased and notes are played in short succession without legato, it causes amp envelope Attack to noticeably increase. (albeit without the pops) This is what my Voyager RME has done since it was purchased new.
I typically use only the Right output, and send the Left one back to the audio input, only engaging the External switch manually, and never saving patches with it on.
If you look in an audio editor at a recording of the Voyager at these settings, the pops show up as a fast rise time up to around -30db when recorded loudly, no matter what the phase of even one oscillator is, and no matter what the amp envelope attack is(up to around 40% of maximum attack time) at the time the VCA fires.
I sent the unit to Moog Music because of this and a bad headphone amp, but they said they couldn’t reproduce the popping behavior. I even explained over the phone that I theorized the problem to be a latency of a few milliseconds when the VCA opens, after the beginning of the CV slope of the envelope.
ie. the VCA’s gate circuit fires after the envelope signal has already started, cutting off the beginning of the slope. I told them this, I spoke to Tony I believe, and he checked and couldn’t find anything wrong. He had also suggested a DC offset in the audio outputs and couldn’t find any. He updated the OS to version 3.3, but I still hear the popping.
So here I have my SCI Pro~One replacement that I can’t really replace it with because of this screwy VCA problem.
Very important to remember is that the popping isn’t noticeable until cutoff is sufficiently low enough. Perhaps the popping is always there, just masked by high frequencies with a high enough filter cutoff.
Anyone else notice this with theirs?
