Hello,
I have the voyager xl and am very happy with the baby.
now i have bought the voyager se plug. dll!
yes it is only in the vst folder (I use cubase 6.5 64bit, win7)
But if I want to start it in cubase, only a white GUI and Cubase appears stuck.
I just reformatted the computer and installed everything fresh!
what it can be.
Before I formatted the computer, I got to run it.
I unfortunately had to reformat the computer again.
I would be very happy if someone has a tip for me
someone has an idea …
greetings from Germany
Axel
Perhaps there is a compatability problem because it is the XL version.
I would write SoundTower to see if this is the case.
I am also running Cubase 6 and have had no problems getting it to load in Cubase.
I installed it as Program Files(X86), Steinberg, Cubase 6, VST Plugins.
However, I’m running Cubase and VST’s at 32bit/Win 7.
Does your Cubase normally work with other plugins in 64bit mode…?
no, I had some problems with some of my older vst’s(Albino, Model E, etc).
Like Seamonkey already hinted…Did you ever try to run everything under 32bit…?
Because i heard more people complain about music software and problems concerning running it under 64bit.
