bonjour,
is anybody trying to install voyager plug se for mac ?
my set up : macpro / 10.6.8 / logic pro 9.1.6
i’ve installed the plug in my component folder like any other plugs
and it don’t show up in my virtual instrument menu.
if someone has the same problem, or a solution…
thanks in advance
anyway i send an email to techsupport ![]()
I installed it yesterday, MacOS 10.7.4, LP9.1.7 - no problems, works perfectly. It appears in the folder AU-Instruments - Moog Music - Voyager_PlugSE. Did you use the root/library path? Macintosh HD - Library - Audio - Plug-Ins - Components > That´s the one I used.
thanks for your response !
yes, i used the same path and there is no moogmusic in the AU-instrument folder
and it don’t appears in the AU manager too. it’s weird.
anyway, if it works with your mac, it should work here !
finaly find the solution !
just launched logic in 32 bit mode, let the AU manager validate the plug
then re-launch logic in 64 bit and now it appears in the 32 bit AU instruments menu
no big deal
