Voyager Plug SE and Ableton Live Cannot get Automation Data
I bought the Plugin a while ago and since then try to get it working as supposed.
My Problem is that I cannot record any automation parameters for my Knobsettings, neither when I use the Plugin UI nor using actual knobs on the Voyager.
The manual is not really good for troubleshooting tips and does not help me further.
I use Voyager PlugSE Version 1.0.0 k in Ableton Live 8.3
Here we go:
-Ableton Midi Settings: Input: Fast Track Pro MIDI In: Track:On, Sync:On, Remote:ON
-Ableton Midi Settings: Output: Fast Track Pro MIDI In: Track:On, Sync:On, Remote:ON
-I Load the Voyager Plug SE by doubleclicking it → It creates a Voyager Plug SE Track
-The Plug SE Track has following Settings: MIDI From: ALL Ins / ALL Channels, Audio To: Master
-When opening Plug SE I have following MIDI Settings:
-MIDI In: FasttrackProMIDI IN flagged red
-MIDI Out: FastTrackProMIDI OUT flagged red
  • Clock On/Off is OFF
    -THRU is ON
    -Polling works and I see the actual preset, I can “Recv” the actual settings too.
    -Voyager Plug SE is set to Channel 1 and is Online
Recording MIDI Notes is working fine it also records the Pitch and Mod wheel, but any Knobsettings (Octave) are not recorded when turning them while playing. Also after playing I cannot record altering Knobsettings, but Pitch and Mod Wheel gets recorded.
I also tried to get the Custom Automation Parameters (Click Configure in Ableton VoyagerPlugSE, then “Send Automation Data” from the Voyager PlugSE UI), I then see a whole bunch of settings and they react when turning knobs but I cannot record them.
Does anyone know what I am missing there?
Thank you for any help,
Daniel
