Voyager output noise issues
Hi fellas,
So I’ve been tracking my Voyager today, and when I turn the trim up on my soundcard to max, I get a shed load of interference when I start Cubase or any other program.
Any ideas ?
Sounds more like a soundcard problem than a Voyager problem. Some internal digital noises bleeding into the audio input of the soundcard maybe ? Or it could be a ground loop somewhere ?
It would help if we knew what your equipment is (what soundcard), and what is your setup (how is everything connected together)…
Thanks man, yes sorry,
Using a MOTU ultralite into a PC.
I’ve tried changing cables and using the same cables with other synths and it’s just normal.
It’s only on the voyager that I get this issue. So strange, that when I open CUEMIX or CUBASE, the noise gets so bad - almost an intermittent, high-pitched sound wave moving up a semitone almost rhythmically…and then when I quit the programs, it disappears!!!
Surely if it was dodgy electrical circuits, then the other synths would behave the same…
