hey all,
so i set out on an experiment to map the pitch intervals on my voyager’s oscillator section. i’m not sure if anyone will really care about this, but here-goes…
TESTING:
fired up a softsynth VST that uses standard saw waves
(note: sine would have been preferred but the voyager doesn’t have sine output) -
matched the waveform (as close as possible). then tuned OSC1 (with the fine tune knob) and the softsynth to unison. also i made sure OSC2 and OSC3 were tuned to OSC1.
used the softsynth to play half-steps up and down the keyboard
leaving the voyage on the root note, disabled OSC1 and tuned OSC2 to match the notes played by the softsynth
compared the voyager harmony with the same interval in the softsynth back and forth
retested later and tried both OSC2 & OSC3 interchangeably.
RESULTS:
tuning direction: DOWN
0 = C (root)
- 19 = B
- 36 = Bb
- 54 = A
- 72 = Ab
- 89 = G
-106 = Gb
-124 = F
tuning direction: UP
0 = C (root)
- 16 = C#
- 33 = C#
- 51 = D
- 68 = D#
- 86 = E
+103 = F
+121 = F#
OSC2 offset = 0 (actual values above)
OSC3 offset = +1 (add 1 to values above)
RESULTS:
something i noticed is OSC2 & 3 share the same tuning values if you take the offset into account. for example, -89 and -88 on both OSC2 & 3 yield a G. i was kind of expecting to have totally different values for both oscillators so i think that is kind of cool. also i went back after leaving the voyager on for a while and the tuning was still accurate.
like i said, i’m sure everyone’s voyager will be slightly different. also due to the nature of analog circuitry, i’m sure my own values will drift over time. however, i was surprised how accurate the voyager’s oscillators track!!
just my observations…
