I just got the PC Editor yesterday. I can get the Voyager to trigger a note using the editor’s built-in keyboard, but when I change a parameter (filter cutoff, for example), it doesn’t change on the voyager.
I tried everything I could think of… plus the manual is very slim and wasn’t of much help. I think there may be some weird voyager parameter that I don’t have enabled. Is there one for enabling Sysex on the Voyager? I didn’t see one… but could have missed it I suppose.
I checked the SysEx Device ID and confirmed that it’s set at 1. It’s really weird, I can play a note on the Voyager from the lil editor keyboard, and successfully receive the bank from the Voyager… but I can edit any of the parameters using the software. When I move a software slider, nothing changes on the Voyager. The users manual is soooo brief that it’s of no help.
The midi seems okay, from what I can tell. I’m using a Midex 3 interface, which works fine with the Evolver Editor I have (I believe both were made from the same company).
You are correct - SoundTower is the vendor that created the software.
Given that the Evo editor works and the Voyager editor doesn’t, that sounds like a configuration issue. Have you tried comparing the setups of the two programs?
If still no luck, email Marc at ST. I’m sure he can help you sort things out.
