The user manual indicates that the Hi & Low Offset parameters work with any programmable source.
The Fixed Value parameter is an offset voltage that can be used by itself or added to one of the shaping sources. Fixed Value has a course adjustment labeled ‘HIGH’ and a fine adjustment labeled ‘LOW’. Both HIGH and LOW Fixed Values are adjustable from -64 to +64 (a total range of +/- 2.5 V).
I don’t hear any affect from this other than when selecting “Fixed Value” as the Programmable Shaping Source. Even then the “Low” or fine parameter doesn’t seem to have an affect.
Why are these parameters displayed for all programmable sources?
