I am using the stereo outs on my voyager, and the dual filter “spacing” adj to sweep
if I make a TRS connector for the voyager mixer out/filter in, can I also split that signal off, with a Y cable, into other FX pedals etc for a separate audio signal? and feed the unprocessed voyager signal back into the “ext in” audio, to get the minimoog self-driven overdrive?
ie: I will take a feed thru external pedals, and run that into another audio input for my DAW
ch 1 = left voyager ( including mixer in )
ch 2 = right voyager ( including mixer in )
ch 3 = external pedal audio loop
I want to use the mixer in as an overdrive, feeding the voyager into itself without the external signal processing. but also run the 3rd audio signal thru some FX
thx!
