Hey guys,
So I’m trying to get my Voyager to work with Blue Cat Audio’s Remote 64 VST in Ableton. I have finally figured out the routing but I am having an interesting issue. When I assign a parameter in Blue Cat Remote… say the filter cutoff, and I move the VST fader up and down, the voyagers cutoff jumps in intervals of 4-5 instead of it being smooth as if I were turning the actual knob on the synth. I have a feeling this is because the Blue Cat Plugin is only sending a range between 0-127 instead of 0-255 like the voyager uses for it’s cutoff.. (maybe I’m completely off base). Is there any way I can fix this?
