¿Voyager + Little Phatty?
I own a Little Phatty Stage II and am definitely buying a Voyager Select Series soon.
Does anyone have any tips and/or tricks about patching these two machines together?
I’m hoping for some kind of analog euphoria when combining the power of both.
Duophonic Moog! It should say in the Voyager and or Phatty manual how to achieve this. Something about key order, I believe.
While douphinc can be cool, you can also use it as two additional osc’s. As posted in other threads about using two Voyagers together you can also set one for low note priority and one for high note and do some cool things where you can play two different sounds, combined or holding a lower key down and letting that sound down and do some things above that note with the second sound.
