sorry to keep bringing this up, but can someone give me a definitive answer on my original question: the internal knob resolution
i see a lot of different numbers so which one is it: 16384? 4096? 256?
the lcd indicator would lead me to think only 256 steps but hopefully it’s much higher, but it’s been brought to my attention that the knob resolution on the voyager is too coarse to allow very subtle osc detuning to perform slow beating like on the phatty line which uses Real Analog Control technology for the knobs…?
Hi Rudy, did you implement a solution that allows you to get every single change of the LSB when through MIDI-out. If so, wow and thank you!!! And how can I get this update?
this is great information; based on what everyone has provided in this thread, I have been experimenting:
unless it’s a placebo, I have noticed that with the display turned off, I get better resolution & more control when tuning multiple OSC
I am curious though: when you save a patch, with display off, does it use the actual 12 bit ( 4096 step ) resolution, or snap the value to a 256 step value?
and then conversely, if you open a patch you saved with display off, then turn display on again, does it change any of the pot/patch values?
maybe it only changes them to 256 steps, if you move a pot?
