So I finally bought this amazing Voyager EB (early versions I think), and I am having some issues.
I found that no matter to which power outlet in my house I connect it to,
when I touch the chassis screws, I get some kind of a light electric shock.
I had the same problem with my Little Phatty when I got it, and the solution suggested by moog was to add a wire between one of the ground leads going to the power supply, and the metal chassis (this solved the problem on the LP).
I wonder if this is a known issue and how can it be solved in the Voyager ![]()
Thanks !
