I have a Voyager Select series and I have just got the 3.5 update, I’m also trying to use the latest version of the editor but it is acting very strangly.
I can select presets OK but if i open the edit section and then adjust any of the controls from the editor it seem to screw up the voyager. It seem to put the VCO’s in to an ultra low frequence mode so that you can only just hear them clicking, any attemps to change the setting using the real controls on the voyager does not work, the only way to get it working again it to switch off and on the voyager.
This has only happened since the the update to OS 3.5.
Any body seen this before and is there a cure?
Paul
