Voyager editor problem!
hi,
I have voyager editor 1.5.0c installed. I have previously saved my presets from my voyager to a mvr file.
Now when I go to load this saved bank it does not load the file. I can click on the file and press open but it does not load them in. Does anyone know why this is happening?
Hi Joam,
GregAE here. This is a known issue looks like it appeared when the Editor was upgraded from the V1.0 version. All versions above 1.0 seem to be affected, including your 1.50C version.
SoundTower is aware of the problem. Until a fix is released, my best advice is to back down to version 1.0 when you need to load/save User Banks, and use the later versions for everything else. (BTW, you must save the User Bank in V1.0 in order to load it back into V1.0. Saving in a later version [like 1.5.0c] won’t load back into V1.0)
Sorry I can’t give you a better answer right now. Hopefully ST will have a fix soon.
Greg
Thanks for the reply.
Yes i saved my bank in the new version now I cannot load it up again. Although I have a bank which was saved in version 1 and it will load up in the new version.
This is something which I thought would definatly not be overlooked. I guess I will just hang onto my bank and wait until they fix it.
this bug is back in latest version for OSX
Version 3.6
