Voyager BNC Lamp
recently my BNC Lamp on my Voyager broke.
http://www.musik-schmidt.de/Adam-Hall-87457-Schwanenhalslampe-BNC.html
And i am looking for a replacement with LED.
Which one will work on the Voyager and is recommendable?
As long as it’s 12V and it’s the right mating connector (BNC) it should work.
I noticed the newer Voyagers have a screw connector and not the BNC bayonet.
you can contact the supplier directly.. hope you could fix it as soon as possible.. good luck!! :mrgreen:
Ah, great, i already figured that the newer Voyagers have a TNC bayonet. Mine is an older model. I couldn´t find subsitute lamps…they look like being from a car…:wink:
Is there an alternative lamp that can be attached to the BNC connector? Something more extraordinary?
In case anyone doesn’t know and just needs to replace the bulb, the Littlite Q 5
http://www.littlite.com/products_accessories.php
I got mine at Guitar Center.
The TNC socket is very easy to replace with a BNC then you have a choiceof many LED lights as it is fairly common on mixing desks to have a BNC light.
Even easier…
Found a TNC to BNC adapter floating around in the lab works a treat. Now the BNC LED lamp from the mixing desk fits :smiley:
http://www.maplin.co.uk/tnc-plug-tobnc-socket-adaptor-1587?c=maplin&utm_source=gcs&utm_medium=gcs_search&utm_campaign=FE83E&utm_content=BNC+Adaptors
