Voyager and Logic LE help!
Hi.
I am totally new to recording in/on a computer. I’ve tried to use the online manual for Logic. I can’t seem to get Logic to play back MIDI to my Voayger. I can record from the MMV both audio and MIDI info and even use the MMV as a controler for the internal instruments. So I believe both then MIDO in’s and out’s are correct.
How do I get Logic to sequence the Voyager?
I have Mac OS X(latest software).
Thanks.
Be sure the Voyager is set to recieve MIDI messages, then be sure Logic is set to transmit on the same channel as the Voyager.
Yeah I did thoe things.
I’ve recored the Midi information on the INSTRUMENT TRACK and the Voyager is going into an AUDIO TRACK.
In the chanel strip is supposed to me in WRITE, OFF, SEND, LATCH ?
