Volume SubPhatty
Hi all,
I am sure there was a topic about this but can’t find it. I find there is a huge difference in volume between presets.
Is there a way to change this?
What is the best way to crank the total sound up (without turning the volume knob clockwise?
Thanks in advance!
not sure if I get your problem..
but if you have the editor software you can set ‘load preset volume’ to OFF.
for the rest it is a balancing act between the main volume, mixer section for the oscillators and the multidrive mostly…
Hope that helps..
You can save the volume with the preset, so you can change it to your taste. There is also a global setting that decides whether to load the volume from a preset or not. You can change that using the editor, but like - every setting you can change using the editor - the manual also explains how to do this without the editor software.
There is a lot to learn with this beauty machine!
Thanks for your responses I will give it a try!
