Hey,
Is it possible to see what midi notevalues its actually syncing to or can I just view the 8bit values?
Hey,
From the manual:
- OFF/SYNC: This setting allows the LFO to be free running unless there is a connection to the LFO SYNC input (see below).
- MIDI: This setting allows the division of the MIDI clock signal (set up in the EDIT mode function ‘MIDI CLK Divider’) to retrigger the LFO. Note that the LFO is an analog circuit, and does not automatically sync to MIDI clock; it is restarted much in the manner of oscillator sync, and does not defeat the Rate control.
- KB (Keyboard): This setting allows the LFO to be retriggered when a MIDI ‘Note On’ message is received.
- ENV. GATE: This setting allows an input to the Envelope Gate Source jack (part of the Envelope CV inputs) to restart the LFO.
So what 8 bit values or note values are you talking about?
