I’m not sure what you mean by Velocity triggering the gate. Are you saying that when you exceed a certain velocity threshold playing the keyboard the envelope triggers? And anything below that velocity doesn’t cause a trigger? What are you using for a gate? Is it external? Under the Edit menu there are settings for the Amp Envelope Gate Source and Filter Envelope gate Source. What are these set to?
Well, I mean, it seems to be opening the filter or triggering the filter envelope more the harder I press.
I’m not using external gate. I don’t have the moog right here, but I’ll check about the envelope gate sources tomorrow.
When I “initialise” a sound in the edit mode, this “triggering” is not happening. Then the velocity has no impact on the opening of the cutoff filter/the filter envelope…
So - I guess there is a way to not make this happen, I just cannot figure out how…
Is Velocity used one of the modulation buses as shaper?
Have you turned the mod busses amounts to zero after you called a patch from memory? The physical position is most likely not matching the stored value.
And Pot Mapping might route Velocity to the filter.
