I just installed the new firmware 1.4.0 and did the Oscillator Compensation Calibration after a 45 min warming-up (the Moog One is actually checking the running time since the last reboot for this). And now my Moog One is in tune in the bass range. No more voices being flat by -12 musical cent. Now it is still analog like, but not as dead perfect as a digital VA synth.
Playing the Moog One is now way more fun to me. Thank you, Moog!
Well, 1.4 broke many of my patches. They sound not the same anymore, big time. I contacted Moog, but they didn’t answer my email. I suspect the filter velocity settings to have changed (maybe a former bug related to that section has been now fixed, with as a result drastically changing the sound of patches that were build around the bug). It would have been nice to hear back from Moog, especially for a synth that costs that much.
No such problems here. Only the tuning is way better in the bass. So I used a bit of PITCH VARIANCE on a few patches where wide detuning sounded better. But I enjoy the other sounds here more well tuned.
But I do notice a bit of glide into the right pitch when playing a bass note with a very short VCA envelope attack time. Maybe they will fix this later. But anyway, it is now playable in the whole range here.
I confirm, so yesterday I decided turning back to the prior firmware version.
In fact, 1.4 is more stable in the lower tunes, but sounds too much different in many of my created sounds (bass sounds).
Turning off the OCC has no effect, I cannot hear any difference.
So I started programming the sound in justifying some parameters and I found
this odd in the Oscillator section:
Try:
Init a patch
Turn Oscillator wave angle / mix so you see a big rectangle on the display
Turn the knob PULSE WIDTH full to the left and listen the sound
Then turn the knob full to the right and listen to the sound.
I hear only a silent and tiny crackling sound.
Is it normal?
I can’t remember this behaviour in prior firmware versions, but I
got this effect in 1.4.0 and also in 1.3.1
Best Regards.
A user on FB had this alternate approach which I’ve been using and I like the way it sounds a lot. Set this up as a mod matrix, you can then save it and import it into any patch you want to sound more drifty. (I then added rows for osc 2 and 3 using Random Keyed 2 and 3):
Source: Random Keyed #1 = 0.15%
Controller: Random Bipolar = 70%
Transform: Slew = 40%
Destination: Osc #1 Frequency
Hello everyone, the tuning of my ONE 16v with firmware 1.3.1 was OK before updating.
Did the 1.4.0 update and after more than 45m i started the occ, it took a long while.
The tuning was not so different afterwards except with occ enabled 1 oscillator is always out of tune when repeatedly playing one note or when that oscillator is in a chord.
Strange, it is like when taking so long to calibrate; the last oscillator has cooled down to much and the occ tuned it wrong.
Disabling occ the tuning is OK, so i leave it off.
At this time it is useless for my ONE 16v.
