I´m still having trouble with the arpeggiator. Its RATE is not ranging from2 to 280 bpm. Sometimes you can only sweep the higher range but most of the time you can´t make it go fast enough. Is there a high/low setting I´m missing or?
If latched I also get hanging notes when switching preset.
Also, do you have something coming into your MIDI IN? It could affect the seeming range of the pot, when it is actually (maybe) setting the division of an external clock…
it may be hard to believe but I actually forgot about the noise fix when I was writing the release notes
I was working from a long list of changes and that change wasn’t on my list; it’s definitely in the v1.0.4 update though.
There was one additional change that didn’t make it into the release notes: Mod Wheel now always sends CC1, even if panel is set to output NRPN instead of CC messages. Formerly, if the panel was sending NRPN, the Mod Wheel would also send in NRPN format. This meant that when the panel was in NRPN mode, the mod wheel stopped controlling external gear. Now you can use NRPN mode (which is useful in Local Off mode because all panel controls send an NRPN, where some don’t have a CC assigned to them) and still use the mod wheel to control plugins or other synth modules.
The buzz, although reduced, is still present. Are there any plans to completely get rid of it or is that not possible because of the hardware? Just wondering.
OSC 1 suddenly only could sweep between triangle and PWM where triangle took up the range 0-8 of the knob and the rest was a little PWM. No saw, no square, just triangle and PWM.
Saved the patch and the knob was working again when I switched the patch back.
