V09.33 OSX AU/VST Supported
I have de installed the editor and removed all the files from the Library directory, then a fresh install. Stand alone the editor works fine, but opening either the AU/VST plugin crashes Live 9.5 32 bit on my machine. I know this was a known issue a few releases ago: Is this still an issue? If not (and this is only happening on my machine) : How can I provide you with log, trace or dump files ?
Best regards
Hans
Hello Hans. It’s impossible to know on which kind of system you are experiencing those issues. Please add those to your signature. Thanks :slight_smile:
Gill,
Signature updated with all the info (OSX 10.11.3 Ableton 9.5/32 bit)
Regards
Hans
Thanks,
But you need to make it show as well :slight_smile:
Regarding the report itself - it’s important information and I will pass it to the developer. He may ask for more info soon.
I upgraded to Ableton 9.6 (32 bits) last night: Same issue. Afterwards I upgraded to 64 bits : Issue gone. Might be a 32/64 bits thing.
Regards
Hans
We will post a new version for testing soon, which is supposed to solve the Ableton crashes. Would love to know if it works well for you. Please follow.
Could it be that it was the 64 bits plugin (x64) running Live 32 bits ?
Salvator
Hello Hans !
Will you check how it works with 1.1.16/0.9.36 ?
Please uninstall any existing version first and clear the preferences. Use the x64 plugs for x64 and x86 for x86 (with no VST adapters).
Let us know if possible, thanks !
