v 9.30 New library sysex file sizes
The preset library isn’t importing the new factory presets. This may have already been reported so apologies if I’m repeating… I’ve not seen anything relating to the new presets.
I’ve copied my older user presets folder into the new ‘sub 37’ presets folder, and they work fine. The new factory presets, however do not show up in the middle panel. i.e. the new unzipped file that’s appeared under the new ‘sub 37’ presets folder (with the HS files) will not load into the panel. I’ve tried dragging from the finder and nothing happens. The small green circle with a + appears at the mouse pointer, suggesting this should be possible.
My own previously saved presets can be dragged into the panel on the editor, and appear in the presets folder along with the factory presets. FYI the new factory presets appear as 381 bytes, my patches are 756 bytes
Dragging from the hardware preset panel to the library panel also works, with the newly copied presets having 756 bytes.
Sounds like a problem with the “new factory presets” file - your file size (756B) is correct; I don’t know what that smaller file size represents but it doesn’t sound like an “all presets” sysex.
the final editor will ship with a full complement of presets, so we’ll review and make sure they’re all correct before releasing.
Thanks for the report!
I think the OP is seeing the extraneous stuff that’s the installer drops in there. It’s not Sub37 related at all. Maybe 0.9.31 fixed it.
