Using Moogerfoogers with DAW?
Hi, anyone here make use of their Moogerfoogers with a DAW?
I’m starting to get back into DAW use thanks to Elektrons Overbridge software and Ableton. My current set up is my Sub 37 and some other bits of hardware being fed into an Allen and Heath dj mixer with send returns going to my 104m and some other pedals, this mixer then fed into the Elektron Analog Rytm and into Ableton via Overbridge. The output of Ableton I have going out to a basic audio interface.
However, I’d like to be able to use my moogerfooger etc to process sounds from Ableton too and have it fed back into Ableton. Can anyone recommend me a good way of routing this and what kind of interface would be best? My budget is a little limited at the minute with the interface. Thanks
Check these out:
http://www.maxforlive.com/library/device/1427/moog-mf-104m-analog-delay
http://www.maxforlive.com/library/device/1205/moog-mf104m-editor
Regarding routing, I prefer to do it outside the box, just record the master output from your mixer when you are done :wink:
They look interesting, will check them out thanks.
So do you mean just have an output from the interface going into the mixer then back into the DAW? The only problem there is doubling up on the audio.
P.s was in Bogota a few months back, loved the place! :smiley:
What I mean is I use the DAW to control external hardware, I won’t record the output from the MF104M unless I want to make some sort of bounce
Glad you came to mi tierrita! If you come again send me a DM
Will do amigo, cheers!
