Using CV out on Subsequent 37 with alternate tunings
I have the chance to pick up the CV-version of Subsequent 37 but first wanted to check a thing (otherwise I’ll probably buy the normal): Does the CV out (when configured to send pitch) work with alternate tunings/scales? So if I pick an alternate scale/tuning on the Moog and control an oscillator in Eurorack - do they play the same pitch?
I guess it works like this, but just wanted to double-check before buying.
Thanks,
The cv out literally sends out a control voltage from 0 to 5 volts, where each volt represents an octave. It doesn’t send note data. So the answer is yes and no. Every single note in every scale is sent out as well as every frequency in between the scale notes in a continuous frequency sweep.
