USB Midi Driver v3.30.0 available, Window 10 feedback needed
Hi all ! Following is Amos’s message about the new version of Moog USB driver, which is supposed to support Windows 10. Any Windows 10 users, please uninstall older driver and download and install this latest one. Please report if it’s installed correctly and can be used with no issues using the standalone and plugin versions of the Editor. This driver also should let you use both Slim Phatty and Sub 37 editor and the same time, please report if it’s now possible to use them both at the same time.
Thanks for your feedback.
_Hello, all!
I have an update to the Moog USB MIDI Driver for Windows. Here’s a link:
http://www.moogconnect.net/downloads/usb/MoogMusic_MIDI_DriverSetup_v3.30.0.zip\
To test this, be sure to uninstall the old Moog USB MIDI Driver from the Control Panel (remove/uninstall programs) before installing the new version.
Important changes in this version:
  • Now supports Windows 10
  • Does not support Windows XP/Vista (contact me if you are using XP or Vista)
  • No longer disables Slim Phatty USB from working (The old USB driver tried to work with Slim Phatty but could not succeed; the new driver doesn’t try)
    Please, if you are a Windows user, try out this new driver and make sure it works for you.
    That’s all the new info.. I hope you have an excellent weekend.
    There’s some additional troubleshooting info below, but if you’ve already verified that the old USB driver installs and runs properly for you then you can skip the code-signing troubleshooting info.
    Kind regards,
    Amos
    …troubleshooting info:
    It is still the case that our driver uses SHA-2 security for code signing, which can create a problem for Windows 7 users unless they have performed the necessary Windows Update first (to add SHA-2 compatibility to Windows itself, which Win7 did not ship with originally). More info about this below:
    Without the update, the driver will seem to install but will not run; if the device driver status is checked, you get an error message saying that the driver “cannot be authenticated”.
    If the USB driver does not work or has any errors, you may need to install the specific Windows Update which enables SHA2 code signing. Below are some helpful links to resolve this:
    Update for Win7 64-bit:
    Windows6.1-KB3033929-x64
    https://www.microsoft.com/en-au/download/details.aspx?id=46148\
    Update for Win7 32-bit:
    Windows6.1-KB3033929-x32
    https://www.microsoft.com/en-us/download/details.aspx?id=46078\
    All other versions of Windows:
    https://support.microsoft.com/en-us/kb/2718704 (follow this link then look for your version of Windows, and click the download link for your version)
    If any troubles installing the Windows Update, try this Update Readiness Tool:
    https://support.microsoft.com/en-us/kb/947821\
    And if all else fails you can delete all the Windows Update temporary files, (located in C:\Windows\SoftwareDistribution\DataStore and C:\Windows\SoftwareDistribution\DataStore), reboot Windows, and run Windows Update again, telling it to check online for new updates. This should find any missing updates for you to install._
loaded and working on win8 without any issues…will be upgrading to win10 soon so can check that too
I’m using windows 10 and did not have to install the USB driver to use the beta. In fact, the readme that came with the beta said it was not needed for windows 10:
SPECIAL INFO FOR WINDOWS USERS:
The plugin version of the Editor assumes you will be using the Sub 37 USB connection for both the Editor and your DAW software. This works OK in Windows 10, but requires a custom Moog USB MIDI driver for older versions of Windows (Windows XP, 7, 8 ). The USB driver is also included in this package. Again, if you are using Windows 10 you do not need to install the USB driver.
So, the question is, do I need it now, and/or will I need it for future version of the Editor, etc?
Hi. Yes, you will need the driver installed also in Windows 10. The docs should be updated.
Thanks.
FYI, i had the driver installed under win8, I upgraded to win10 and the standalone couldn’t find my sub37. I had to removed the driver and resinstall and all is good now.
Slim Phatty and Sub37 are working now together with the new USB driver!
BR Michael
X64 driver is working fine after updating the Security Update for Windows 7
Regards Luloop
Thanks for the feedback !
installed the new driver on my Windows 10 PC. Got a SmartScreen filter warning, but after I clicked “run anyway,” the installation went smooth
I verified that I can run the stand-alone Editor (v0.9.29), Geniesoft/SonicScores Overture 4.1 and MIDI-OX simultaneously and each can talk to the Sub 37 and vice versa.
No odd behavior observed … yet :smiley:
still running 1.1.13 firmware, will check again after I update to 1.1.14 this weekend
