Does anyone know how we can save under the hood settings so that when i power down i can get them back without needing to plug in USB? (i dont know if this is possible)
I thought they were saved automatically
That would suck if they are resetting every power cycle. What params are you changing? i can check to see if mine is doing the same
LFO retrig, external input volume, and note sync…
Ok i found that the under the hood settings are saved individually per preset. If you tweak them you have to re-save the preset. Its not global. Hope that helps!
Thanks for the reply Grinder. Im gonna look into that tonight.
So heres what i found…
All under the hood parameters seems to be loading up just fine when i power up again and navigate to a selected preset…BUT…
If i save a patch with LFO retrig and navigate to it outside of the editor (using the glide shortcut) the mod being controlled by the LFO totally dies. I can see the LFO light flashing and retriggering as expected but the Pitch and Filter mods dont work at all. If i navigate to the next patch that doesnt have the LFO retrig enabled, the Pitch and Filter mods work fine again.
Can anyone confirm this behavior?
