Trying to play Voyager with drum pads...
…but it´s working quite poorly. The Voyager reacts in kind of a random way. I have to hit really hard and still it triggers just once in a while. I´m using an Alesis Control Pad which works just fine with a Nord Drum and I tried it with my Roland JX8P. No problems at all. Are there some settings I need to make to make the Voyager getting trigged properly?
My overall impression is that there´s much to ask for MIDI-wise with the Voyager. A while ago I had troble with turning some MIDI-notes of so my MonoMachine (I think) could control notes but not some random value when I was tweaking some parameter that wasn´t at all related. No, it was the other way around! I wanted the Voyager to play the MonoMachine and have the two layered, but when I adjusted the filter or something on the Voyager, there was something getting tweaked on the MonoMachine as well. I then downloaded another version of the software for the Voyager to be able to design what MIDI to send. Could that be the issue in this case?
Here´s the thead I started about that issue:
http://forum.moogmusic.com/viewtopic.php?f=2&t=22215
To be honest I really hate MIDI issues because I can´t get my head around them. I really don´t grasp how it works and what parameters and possibilities there are and it really frustrates me.
Got to it again today. I can adjust the Voyager so the notes sound as I want them but only about four of five hits triggers a note. The Voyagers MIDI In lamp lights up all the time though.
Tried tweaking the Voyagers MIDI settings. Turned off almost all MIDI CC in. No difference.
Hi MBlom,
This is just a shot int he dark, but I’m wondering if the Gate Times from the Alesis drum pads are extremely short.
By that I mean the length of time from a pad’s MIDI Note On to its MIDI Note Off. With keyboards, we typically hold the key a lot longer than a drum pad’s default Gate Time.
Quite often, a drum pad’s Gate Time is the absolute shortest amount of time allowed by MIDI.
This could be the cause of a Voyager patch not having enough time to actually make a sound.
Give this a try:
See if you can edit one of the pads to have a longer Gate Time (or Note On Time, Duration, etc.)
If you start hearing the Voyager, you’ll know how to fix it.
There may even be a Global setting in the drum pads to lengthen all the pads’ Gate Times at once.
The Memorymoog has a feature called unconditional contour, meaning the EG would complete its full ADSR contour regardless of when the key was released.
That would be the ideal solution, but I do not see any such option in the Voyager. You may have to adjust the gate time in your drum controller.
