I’m new to this forum and hoping for some help. I’ve had my Matriarch for under two years and have come across an issue today that I don’t recall noticing before.
When I’ve got it in the two-note or four-note paraphonic mode, I’m noticing the higher note cutting out.
This is happening if I play two, three or four keys at the same time, or if I play the higher note just before playing one or more other notes. Also, if I play an arpeggio going upwards (lower notes to higher notes), there’s no issue because the highest note comes last, but if I play an arpeggio going downwards, the higher note cuts out as soon as I play the next note.
It’s as if any lower keys are causing the higher one to cut out - but only if the higher one is played at the same time or slightly before, and only the first of the higher notes.
I have only noticed it happening today, noting that I have had it on its current settings for a while.
Is this a known issue?
I’m not experienced with synths and I’m not great with the terminology, so I hope what I’m writing makes sense.
