Does anyone know how to use the triplet part of the MURF’s software?
What OS is your Murf running?
Triplets were added in the newest OS. They can be turned off by midi CC if you want the knob controlled rate to stay with power of 2 intervals. If enabled you should be able to select triplets using the rate knob.
From the OS1.8 addendum:
CC66 – Triplets Disable: Values 0-63=OFF, 64-127=ON. If a CC66 message value 64-127 is
received, this will disable the Triplets time divisions from being selected while in MIDI Sync. The
purpose of this is to allow you to sweep manually through the different clock divisions (using the
Rate knob or CC9) while preserving 4/4 timing. Triplets will remain disabled until a CC66
message value 0-63 is received, or until the MF-105M is powered down. The unit always powers
up with triplets enabled. See Clock Division charts below for more info.
If you want to use midi CC to control of rate, Use CC9 with the following values:
Clock Divisions - Triplets Enabled
Duration CC9-values
Four Wholes 0 - 6
Three Wholes 7 - 12
Two Wholes 13 - 19
Dotted Whole 20 - 25
Whole 26 - 32
Dotted 1/2 33 - 38
Whole Note triplet 39 - 44
1/2 Note 45 - 51
Dotted 1/4 52 - 57
1/2 Note triplet 58 - 64
1/4 Note 65 - 70
Dotted 1/8 71 - 76
1/4 Note triplet 77 - 83
1/8 Note 84 - 89
Dotted 1/16 90 - 96
1/16 Note 97 - 102 6
Dotted 1/32 103 - 108
1/32 Note 109 - 115
Dotted 1/64 116 - 121
1/64 Note 122 - 127
Clock Divisions - Triplets Disabled
Duration CC9-values
Four Wholes 0 - 7
Three Wholes 8 - 15
Two Wholes 16 - 22
Dotted Whole 23 - 30
Whole 31 - 37
Dotted 1/2 38 - 45
1/2 Note 46 - 52
Dotted 1/4 53 - 60
1/4 Note 61 - 67
Dotted 1/8 68 - 75
1/8 Note 76 - 82
Dotted 1/16 83 - 90
1/16 Note 91 - 97
Dotted 1/32 98 - 105
1/32 Note 106 - 112
Dotted 1/64 113 - 120
1/64 Note 121 - 127
