So when I press the trigger button on my DFAM, it generates a much louder, punchier sound than when played from the sequencer. It’s like adding EG or something. I’ve tested this a lot and I’ve made sure that I’m comparing the same steps. Nothing is patched. I’ve also tested this with my MAFD module which adds midi to the DFAM and its the same deal. Anyone else experiencing this behavior?
I’ve tried comparing the TRIGGER button against the sequencer trigger, taking care that the decay part finishes before re-triggering. And indeed there is a difference in response, although on my DFAM the difference is minimal. It’s as if the TRIGGER button leads to just a little more higher frequencies content.
There may be a logical explanation for the difference, but I can only guess at the reason why without having seen the circuit schematics.
This issue occurs when applying VCO EG. The more + VCO EG applied, the more out of sync the trigger button goes with the sequencer. At 0 VCO EG, trigger matches sequencer, after 3 'o clock they start sounding different. I also had a chance to test a couple of other DFAMs and this issue was more or less present on both so I guess it is what it is.
