tried everything......audio in no sound
I have received my minitaur yesterday and the experience so far was not a good one. I had big trouble with the drivers on my win 10 and now I cant get the Filter(Audio in) working.
I have a lot of outboard gear so Im not a total noob but this one I cant get to work. I had it work once and didnt change anything but now its not working anymore.
I have set it up like this in ableton:
Audio Track → output 3 where my interface is going into audio in of the minitaur
Midi track with external instrument I get a sound from the unit itself so it is receiving midi and is connected properly.
Both osc are turned down
filter cutoff is set to 20khz
EG amount to zero(middle)
LFO all the way down
AMP Attack:zero; decay/release and sustain all the way up
VCA loud enough
I let the track running and press the midi keyboard but no sound…
So What am I missing here?
MIDI CC #27 is adjusting the input level for external audio in on the Minitaur. Maybe this is set to a way to low level?
And did I get it right: if you tun up the levels of Osc1 and/or Osc2 you hear the Minitaur playing?
