I’ve noticed some of the settings in the master menu are non-programable. It this true?
When I set the midi transposition in setting to other than “0” it is only stored until I power down. When I turn the Voyager back on, it always defaults to “0”. This is bad. I know that I could set the keyboard I use to controll the Voyager to transpose, but maybe this is/will be fixed in ver. 3.0 or above OS?
This thing is the BEST SYNTH I’VE EVER OWNED! (and I’ve owned 'em all)THANK YOU DR. BOB!!
Frederic, I think this was done this way on purpose. So many people would go nuts if the transosion they did the last day would still be stored. Most likely the user would have forgotten about this by then. And keep also in mind, the although the Voyager acts fine as a little master keyboard, it isn’t its main usage (but I also use it now and then outside my studio).
