Looks like it. I can’t stand the smell since I quit. And I NEVER liked the smell of stale smoke.
i own a industrial grade ozone unit (20-30 times stronger than the residentual ones a lot of people have) that will remove any stench of cigaratee smoke
(and life, bacteria, and Humans for that manner)
i worry about the buildup on the circuit boards… electronics/ electrostatic fields attract all the tar and nastiness…
This is somewhat true. What can happen, and what I’ve personally seen, is that tar builds up and causes shorts. Alcohol and a soft cloth will remove most of that to the point you can clean between components with a Q-tip or twenty. Aside from smoke, dust can also clog vents, and cover heatsinks, resulting in a fire hazard and/or failed components due to a buildup of heat. In other words, anything that will get into electronics needs to be removed periodically from the electronics. ![]()
