Theremini as midicontroler in Ableton
I want to use the Theremini as a midicontroler for example to do filter modulation inside Ableton. The Teremini is listet as connected as input and output in midi ports. But I can’t control anything. For example when I start Massive standalone I can control it with the Theremini. Anyone any Idea about this? Thanks a lot!
The Theremini works as a controller with two parameters, each of which sends one continuous controller (CC)
It is not intended for use as a replacement for a MIDI keyboard, is this what you are looking for?
