HI Gamaliel, I had some issues with my Moog once I got over the initial buzz of it, and it ended up being replaced. I guess I was unlucky but like you even on my replacement the mode toggle switch falls off and I still have a very minor intonation problem I can live with.
There is so much this guitar can do, it is a pity that it is so expensive.
I did use the Mediums for a while but on the replacement guitar it was so well set up at Sweetwater, that I kept the Heavies and now that I have a good guitar, you can hardly tell the difference between the heavies and the mediums.
It is a pity the Thomasticks don’t work, as they really sound great and last a long time.
I seem to be going through Moog strings rather rapidly. I guess about one set per week, and if I am actively recording then it’s one day to settle and 2 days to play maybe 3 and then start all over again.
I am seriously considering putting the Roland controller on it, but I am concerned that there will be some interference from it or from the Moog that will affect either the guitar or the Hex P/U, so a stick on run is the way to go at first.
That would have to be an ultimate guitar, but I am a bit hung on analog, it is a pity everything has to end up in Digital anyway.
I am going to experiement with a lot of Moog’s stuff before I try and mod the guitar though.
I mean Moog revolutionized music, I have a feeling that this guitar or at least a version of it, also has a similar potential.
Moog Guitar V2 is going to be really interesting, unless it is a cut down Moog for the standard reasonably priced market. (Is anything reasonably priced even in the USA). Think about paying for the Moog guitar in British Pounds. Now that’s expensive.
Stuart
