The arpeggiator is missing notes sometimes
Hi all!
I have a LP II since long ago and I have always had a timing problem with the arpeggiator. The problem is that a note is not played from time to time and a silence is played instead. I had never paid much attention to this but now I’m considering using it live and now it is.
I read something related to this in the forum but I have not been able to find it again.
Steps to reproduce: turn on the arpeggiator, turn on the latch mode, play a chord and wait. It will appear at some time, specially while tweaking the knobs.
Firmware is 3.21 690/33.
Is this problem common? Is the internal clock source reliable enough to be used live? Does anybody know a solution for this?
TIA
Check out this thread, specifically the last page or so:
http://forum.moogmusic.com/viewtopic.php?f=7&t=20826&start=60
Evidently the last firmware update fixed most of the problems folks were having with the ARP & poly-chain! :slight_smile:
Haven’t tried it myself yet -
on the “to do” list…
Stuka,
thanks for the link but I had already installed the last release (Vers:3.21 690/33 as said in the advanced menu) and the problem was still there.
I always thought that my problem was a common one and that it was going to be solved in the future. Buy now it seems it’s a deffective unit or a misconfiguration, which I hardly believe. That was the reason I was asking if anyone was having similar failures.
I have just tried if the problem solves if the clock syncs to midi but it keeps missing notes. While I was testing I have realized is very easy to replicate if you move the pitch wheel quite a lot. It sometimes misses notes or play it a bit late (out of time).
So, the question is still open. Anybody having similar issues?
