terminate a Moogerfooger CV externally
HI, how do you terminate a Moogerfooger CV externally? Like if you plug a TRS patch cable into the feedback CV on an mf-104z, the feedback control knob on the pedal does not work correctly? I am building an A/B box with a bypass switch to switch between 2 pedals or Moogerfooger CV inputs and 1 expression pedal. I need to know how to terminate the CV in the A/B box so the Moogerfooger CV knob works correctly when not overtaken by the expression pedal.
Thanks,
I don’t really understand your question. As I understand, the knobs always work correctly, even if you plug anything into the CV-inputs. The signal at the CV-inputs is added to the signal of the knobs.
Hi, try plugging a single TRS patch cable into that CV, the middle position is a low setting and turning the knob left or right increases the effect. The knob
