Tech help with my OB1
Well since there is no Oberheim forum maybe you guys can help me out.
My OB1 has intermetint noise problem. While playing the keys I hear noise sorta’ like when you’re listening to the radio while a lightning storm is near. It’s on both VCO’s. I’ve turned all the knobs to see if maybe it’s a dirty pot or something but no luck. I’ve also gave the noise source switch a workout thinking maybe it’s dirty but no luck on that either.
Anyone?
Who’s a good synth mechanic?
Cole
:cry:
Talking about having problems with the instruments you have did you check is there anything that might cause this to happen? What I have in mind is that there must be a cause for it. And you definitely need a sign about what is going on with your instrument. If your problem is still not solved yet, I would advise you to hire somebody or sent it to a shop and check that would save a lot of time and effort.
