In a late night fit of EUI ( eBaying under the influence) I bought a Taurus II. Apparently functional but with no pedals, just the brain. Am I boned or is there just a stock CV in on the back? If so, I can just play it from my Voyager or MS20 then. I really just wanted it for it’s “flabulous” sound.
the taurus II has trig in/out and keyboard in/out jacks on the back. you can use your voyager if you’ve got the vx351 (unless your voyager is an old school…no need for the vx351 then). not sure if the taurus II’s trig in/out can be controlled by your vx351 gate jack…hmmmmm. maybe you need some cp251 attenuator control or some tricky cable to make it all work…
Is the keyboard in 10v/octave? The MS20 could run it.
or you could get one of these…
http://www.synhouse.com/midijack.html
and use a midi keyboard controller
