I have tested the new firmware at our band rehearsal two days ago: The MIDI Filter settings are now working for my setup (MP-201, Taurus III, DSI-Tetra) like a charm.
Big thanks to Amos and Moog for the support of an already discontinued product.
Can anyone please confirm or deny if the link Amos posted to the new update is still working or not?
I just tried to download the update to see if it would help me with my clock divider automation issue but i just get jibberish when i follow the link.
Thanks guys.
Direct links:
Windows:
http://www.moogmusic.com/sites/default/files/TaurusFWUpdate_v2_0_2_5Jul12_WIN.zip
Mac:
http://www.moogmusic.com/sites/default/files/TaurusFWUpdate_v2_0_2_5Jul12_MAC.zip
Thanks mate
Any news on a further firmware update for the T3?
- Matteo
i really would love that, Amos
It would be awesome, I haven’t been able to use 2.0.3 and version 2.0.2 still has bugs…
nothing til after NAMM I think… I have too many projects until then to look at T3 again. I’m not done here though; I will do more work on Taurus 3 in 2014.
That’s certainly welcome news, Amos! Thank you for all the hard work you do. ![]()
I’m still running the original firmware on my T3, but have read with interest the various postings in relation to the updates. I generally like to download all software updates on computer programmes and operating systems but still feel very cautious about updating my T3 after having read the postings by T3 users who have experienced problems during and after the installation.
I use my T3 for quite basic requirements and don’t currently use the features such as the Arpeggiator or Midi, therefore is the latest Version V2.0.3 both safe to install and are there any improvements which have been made which may be of actual use to me?
To summarise, is it worth installing it unless you specifically intend on using the above features or would it be better to keep it with the original firmware which works very satisfactorily.
I can’t even remember the first firmware version. I know my main issues were with MIDI. I think they were mostly addressed in this update. Anyway if you’re not using MIDI or Arps then I would definitely do the update as it adds some nice features, like storing patch wheel volume, the presets 1-4 can be overwritten, you can assign volume and filter cutoff and resonance to pedal velocity. You can make the LFO restart on note start. Not sure if it always did this, but you can play a note with a long decay, hit the next patch without it changing and the new patch only sounds when you hit the next note, rather than cutting off immediatly ou select the patch.
Some nice features even for the non-MIDI user.
If you have a copy of the older firmware about you could always reflash back to 1.0 if you don’t get on with it.
The original firmware has a bug which I discovered a number of years ago. It involves the arpeggiator, and has something to do with I don’t know what. I caught the behavior on video. https://www.youtube.com/watch?v=wZGq-Nf2TQg
Might give it a go then.
Do you install it via midi-ox or direct from the zip file?
MIDI-ox.
Do you need to back up your own Custom Presets before doing the upgrade?
I would, just to be on the safe side. ![]()
Updated to v2.0.3 last night. Glad this was out there, as it fixed an issue previously unreported, as far as I can tell, with v2.0.2. When I upgraded from v1.13 to v2.0.2, the T3 stopped responding to midi volume control (yamaha mox6 → T3 via midi DIN). v2.0.3 fixes this problem. There is another problem that is still present in v2.0.3, and was also a problem in v2.0.2 and v.1.13, having to do with the midi merge feature. When set to merge the midi input onto the midi output, all input commands to channels other than the T3 (mine is set to RX/TX on channel 2) get output with the channel id of the T3 instead of the channel that was originally sent. Perhaps this was intentional, but it seems to defeat the purpose of having a midi “thru” feature. Not a killer problem, as I can always add a dedicated midi thru box.
Thanks for reporting this.
I do think it is not right, MIDI messages shouldn’t change their channel. Hope it will be fixed in the next version.
Alas, I spoke too soon. Wife was trying to sleep, so I had the volume down and did not realize the T3 was not going to full volume when commanded. The T3 is apparently setting the coarse volume to 0 and the fine volume to 127 when receiving the 7 bit MIDI volume CC at 127. The midi output is also hosed; watching the midi output from the T3 when changing the T3’s volume wheel you see the coarse volume going from 0 to 127, while making very small changes at the wheel, then you see it go back to 0 and on up to 127, over and over until the volume wheel is actually at maximum. I have gone back to v1.13, where the T3 correctly responds to midi volume control. I do occasionally experience the stuck note phenomena with v1.13, but this happens rarely and I can at least work through my practice sessions successfully. Fortunately, I have never had a note latch up like this during a gig.
thanks for the report; I will fix this as soon as possible.
There is an outstanding note latch bug on my list as well.
cheers,
Amos
