hi
maybe someone has the same problem, but if i tap tempo the lp and the beat is 130 bpm , the lp only gives 129 and 131.
this is very weird.
someone has the same problem?
chris
its not really a problem its just really fidgity / sensitive.. I get the same thing.. if u play around with it u can get 130… maybe there will be a fix for this later? I get the same thing when dialing in specific BPM’s… takes a big of redialing to get to the exact number i want sometimes.
When dialing in you can adjust in .1 BPM to get it right on. I’m not sure what OS introduced this. I’m running 2.1. It’s also nice when synching gear the old fashion way.
A later OS also added an average function on the tap tempo to make it more controllable. The last several tap ins are averaged together.
