I presume this is what you are talking about:
http://www.petersontuners.com/sonuusgw
In general, I am against any pitch to MIDI conversion for several reasons.
First, there are latency problems and false triggering. Clearly, this unit is being marketed based not on low latency like the “Axon”:
http://www.axon-technologies.net/modules.php?op=modload&name=Sections&file=index&req=viewarticle&artid=84&menu=10103
But rather, “robust triggering” which means, less false triggers. I agree to some extent that the problem with guitar synths is more an issue of false triggers than latency although latency is certainly an issue.
This unit also does not use special pickups. In many ways an advantage but also realize that its those special pickups that allow each string to be a separate MIDI channel allowing for special tunings and other interesting MIDI triciks.
One must realize that latency is an issue that can’t be eliminated. It’s not a matter of better technology it is inherant in how units such as this determine pitch. Without going into the mathematics, which I do understand, there is an inherant blur between time and frequency.
Some have commented here that the freqbox responds very fast. It actually responds in an instant because its not converting frequency but using hard sync. For this reason, and why I really like it, its organic.
I also did not buy my freqbox for guitar. Frankly, I don’t need to make my guitar sound like a synth. I play keyboards as well. I also have one of these:
http://www.starrlabs.com/
Starr Labs makes custom fretboard based MIDI controllers. It’s more like keyboard in the form of a freboard. It has no more latency than a MIDI keyboard and it will not mistrigger unless you play the wrong note. It also has some awsome advanges. First, you can play chords and second, you can do some incredible things with tapping and right hand technique. Example:
http://www.youtube.com/watch?v=4FjYdxAxwaA
Bottom line, I let a guitar be a guitar. In many ways, outside the cost issue, Moog was smart to create the Moog Guitar. I really like it just not the price. The Moog Guitar does no pitch to MIDI conversion. Its a guitar but it has some enhancements that expand what a guitar can do.
What I also don’t like about pitch to MIDI is when it translates pitch, it sound unatural on a oscillator. The transient portion of a not is highly complex If you look at a sonogram of any non bowed, no perscussive instrument you will see that after the initial attack phase, the sonogram will stabilize but before then, it is complex.
I have spend a lot of time working with additive synthesizers and it’s really for this reason that I am not a fan of additive synthesis because I understand the limitations of the model that tells us that any sounds is just a serious of harmonics that change pitch and amplitude in time. This is not really true but again, I will not go into the mathematics of it. The fast fourier transform, what is used for pitch to MIDI, makes sense for a stable waveform but when we are talking transients, time has to be windowed, broken up into frames, and thats were the whole problem comes in. Bottom line, it does not work and to me, pitch envelopes for pitch to MIDI sound artifical to me.
Guitars have great transients. Its what gives each guitarist a unique sound. Why we want to turn them into a synthesizer is beyond me other than a guitarist wanting to be able to play a synth and the ZTar will do that. A freqbox is not a synthesizer. Its a hard sync effect which has been around for a while but a nice implemenation by Moog. Its organic, analogue and beautiful.
Now I would like an analogue pitch follower but no pitch to MIDI.
I have a MIDI to CV but I got that to integrate with my digital synth, not my guitar.
