I accidentally hit some buttons and now I cannot get it to default to the Taurus I setting.
I’ve tried a Factory Restore and Reboot but still it won’t reset to the factory default TI when turned off then on again.
It’s defaulting to “E2 Extreem Detune” “CUTOFF: 3368” every time I turn it ON.
Please help.
Thank you.
First thing Moog will probably till you to do after a restore is to try reinstalling the Firmware.. Might wanna use your favourite Sysex utility to backup any custom presets while you’re at it also.. hope that helps..
Strange problem to be having.. haven’t experienced anything similar to that myself. Goodluck. ![]()
I found my problem;
I had hit “Bank” by mistake and when I followed that with hitting one of the pedals it changed the presets/bank.
So I hit “Bank” then a “C” note. That brought me back to normal.
Whew….Thought I had a terminal brain-fart there that wouldn’t go away.
