Synth stand advice
Any advise on a good 2 tiered (or even 3) Synth/Machine stand.
My current set-up is P08 + Voyager. I’d prefer having the Voyager on the 2nd Tier, but it weighs more than the P08.
Any suggestions?
I use an A-frame shapes Ultimate Support stand for more then two decades.
But also the Aphex stand works well, if you use the long tiers.
check the quiklock ws 550 plus the second-tier support (I don’t remember the product code but any quiklock vendoir will know if you ask).
It’s got four legs on the ground (no jokes please :blush: ) and won’t tilt no matter how heavy is the upper-tier keyboard.
I use it, with my voyager on top [again, pls… :blush: ]
and a way lighter keyboard on bottom,
and its definitely stable.
Legs are variable/lenght, and the horizontal distance between the two keyboards can be adjusted and stabilized (i.e.: for getting really close keyboards, organ-like) using screws or modifiying the supports.
It was not originally built as a keyboard stand, so it’s not often advertised as such (it’s theoretically a mixer stand),
but quiklock in fact built a lot of keyboard-related accessories for it (second tier, various supports).
worth taking a look, and doesn’t cost a lot
A few months ago i switched to a stantastic 3 tier stand couldn’t be happier first tier is my novation master controller second tier is voyager and third is jupiter 6. I even have room for a small 4th tier if i wanted to toss some other equipment up top.
I’m SELLING my Standtastic 3 tier stand for a hundred bucks, if anyone wants it.
Quiklok
The ProLine PL402 works very well.
Ive seen a quicklock hold two 88 key units. I have my voyager sitting on one right now. Great load bearers they are. Voyager has sat on the top before.
I use an older Quiklok stand that is very similar to their QL-642 - it has a Jupiter-6 on the bottom tier and a Voyager on top; probably 100 pounds of synth in total, and it’s no problem at all. Very stable and reliable, although the stand itself is a bit heavy when loading in and out of gigs.
Amos
I use an Ultimate column stand for a Nord Stage or korg Karma on the lower tier and a Voyager on the top,if you raise the top tier to the maximum height it sits there perfectly
