I want to use midi out on the Sub 37 to sync the clock on the subharmonicon. I seem to be failing dismally. I’ve got “send clock” set to on. I’ve “set keys” to off. But there does not seem to be any clock being sent to the subharmonicon when the arpeggiator is playing.
Any ideas
Are both midi ports set ON (at least DIN)
Can you test on another device if the midi is sending the clock (to make sure the S37 is the actual issue)
