Syncing Sub 37 sequencer to DAW
Hey Guys,
Relatively new to the Moog Sub 37 and yes I have read the manual and researched this topic every where but still for some reason I cannot get the SUB 37 to sync to my DAW.
I am using a Sync Gen Pro II and this is how I currently get my Pro 6 sequencer, PRO 2, and Analog Keys sequencer to sync tight to my DAW.
It seemed easy and logical to set up on those machines, but really struggling to get the SUB 37 to work.
I am guessing its got something to do with the settings, I have tried changing the midi settings but still no success.
What i would like to do is to use the internal sequencer on the Moog to create a sequence, then to press play on my DAW, and for the Moog sequence to start…seems easy right.
Could someone please kindly help me with an easy step guide to get this working?
I would really appreciate the help.
Where am I going wrong, as i know the sequencer can sync to midi clock.
If sync is enabled (next to arp rate), then you could always send a midi note to the sub 37 to kick it off in latch mode, or a sustained note if latch is off.
Okay I will experiment with this.
