Syncing SUB 37 for live performance
Hey, kind of a noob question here. Sorry.
I’ve been wondering how you can tempo sync the arpeggiator with the rest of band when playing live.
The tap-tempo is always a little off (I’m a little off). Is it possible to do a “fixed tempo” of fx 134 BPM?
Currently, we’re using a click track via Logic, but since we’re only using one synth, I’m wondering if syncing via an external MIDI clock might be excessive. Is that the only way?
Thanks in advance
Hi, welcome to the forum!
Nothing seems excessive as long as it helps :slight_smile:
Here are a couple of options.
Ploytec 34One or One.2 are pedals that will allow you send a MIDI clock signal to your synth after you to tap a tempo.
The Midronome will allow the same: MIDI clock’ sending and tap tempo… plus other functionalities.
The MidiClock seems to have less features but may be useful too.
Hope this helps!
